Re: Help! Broken lower unit bolt. 1981 90 horse johnny
OBJ, There are no pieces of the bolt protruding through the lower unit at all. This bolt is small. I removed 2 bolts on each side of the LU. One right above the prop ( a little bigger bolt than on the sides)and one underneath the trim tab. So six bolts seemed to be holding the LU on. The one I broke off is in between the trim tab and the other bolt that held the LU up. If I listed the bolts on LU from the front to the back they would be 1-4 on the sides, 5 (came out), 6 (broke off), 7 (under trim tab and came out), 8 trim tab. Does this help describe the bolt that broke? It was not doing anything before I started this except plugging a hole. Hope I don't need this one to hold the LU on as drilling it out is tricky with all that nice soft aluminum surrounding it!<br />10,000 Lakes and no boat!
