HELP! can I tap power for vhf to run a stereo??
popeyefoghorn
Hi I'm going to wire in a car stereo into my boat. I was wondering if I can just tap into the wires running to my vhf to get my 12volts?? Will the vhf and stereo interfer with each other? Also can I mount them side by side (8inches apart). Thanks for the input.
sloopy
Re: HELP! can I tap power for vhf to run a stereo??
You should supply your stereo with its own breaker or fuse. I have seen stereos mounted two inches below a vhf, but I do not know if it will cause interference, sounds like a question Thom could answer ;)
18rabbit
Yes and no. If they are the factory wires that came with your VHF, they are designed to carry the current for that piece of electronics equipment only so using those wires to also supply current to your stereo is not a good idea. If the wiring size is appropriate for the current of both units then in theory you can share the wire, but it’s not a good idea. Also, the shared line should have its own larger fuse or circuit breaker and each piece of equipment should have it own fuse as well.<br /><br />As a rule of thumb VHF is considered sensitive electronics and as such wants it be connected directly to a clean power source. In reality, the quality of VHF electronics can be really good, depending on your unit, and may be much less sensitive. Your stereo is not as sensitive, but the radio in it is. Bottom line: it’s not a good idea to share the pwr/gnds.<br /><br />Both units come enclosed in metal boxes for a reason. They will not meet standards for stray RF without them. They are specifically designed to NOT interfere with other electronics in close proximity to either unit. You should be able to mount them in close proximity to each other, as Sloopy mentioned.<br /><br />Something else to keep in mind, the electrically produced magnetic fields is not enough to have an effect on either unit; however, cumulatively it may affect your compass. Be sure to check for this if both units are install near each other and within 2 or 3 feet of the compass. Check the compass with power supplied to both units together.
popeyefoghorn
Thanks guys, well I'll check into the wire guage to see if it would be sufficient. If not I'll wire the stereo on its own. Now about fuses what would you recommend? Would it be the same as the vhf? Maybe this is a stupid ? but I don't have the stereo infront of me right now...I'm at work. (just givin 'er too!)
Boatin Bob
Depends on the stereo, most today come with a fuses(s) right on the back and some others come with inline fuses in the 2 power lines (main power and memory power), you should use the size the manufacturer recommends and I would agree with the others about running a separate power line for the stereo, you want clean power for both the stereo and the VHF.
popeyefoghorn
Well its the long weekend up here in Canada...so I'll put the stereo in this weekend and let you know how I make out. Thanks for the info. and have a good one!
