66stingray
- Joined
- Nov 8, 2015
- 12
Hello,
New member and relatively new boat owner. I have a 2005 tracker marine Tahoe 254. Its considered a deck boat with a 350 Mag mpi, 300hp and bravo one sterndrive. The gear ratio is 1.5 and the boat weighs approximately 2,800lbs without engine, roughly 3,800 with the engine and has a 63 gallon gas tank. Its mainly used in a Bay environment in NJ. Wot is approximately 4,800 to 5,000 rpms. I have taken the prop off during winter storage and want to replace with a new aluminum 3 blade. Current prop is a 3 blade aluminum 14.5 with 19" pitch. My performance at the moment is good, gets up to plane quickly. I am considering sticking with the current spec (14.5 - 19") or changing to 15 - 17" pitch, still 3 blade. By changing diameter and also pitch, the 2 should remain at the same rpm range. What advantages/disadvantages will the difference in diameter have if at all? Looking for all around performance, don't want to lose any top end speed.
