Help clearing cylinder of gas
stevetedder
Re: Help clearing cylinder of gas
You used a flashlight to see inside the cylinder right? Use a match and the problem is solved :) Either pull plug and rotate flywheel, rotate motor upside down or try something like a syringe or small hose to draw the fuel out. Just a couple of thoughts.
