I have a 87 50hp VRO Johnson that has rough idle problems, I have been messing with it for the last 3 years, I have rebuild carbs 3 times changed plugs 2 times- champion QL77JC4 - Using fresh fuel - use decarb foam spring-fall & mid season sence new. Had sink & link done twice in the last 3 years. Changed thurmostat last week it was stuck open, used decarb again, this helped a little, going to check reeds next! also checked compression again it is 145psi on both cylinders!! Dose this sound right, can't find comp psi in my manual.<br /> THANKS!! SKELLY.
