Help convert 91' johnson20 hp to 35 hp
hey everybody im new here but will be a owner of a 91' 92' 20 hp johnson short shaft and would like to convert it to the 35,via reed plate,intake,carb ,my question is what part numbers to go after? the intake i want to get so i dont have to do any porting so the correct 35 part should avoid that? any ideas of how you guy have done it? this mod sounds doable thanks
BigB9000
Re: Help convert 91' johnson20 hp to 35 hp
Well, I know nothing about this. I looked up the crankcase, crankshaft, and pistons (all are the same) sounds good in theory.
0396790 MANIFOLD, Intake. 30 & 35 Models Only 1 $145.91 USD
Leaf plate is the same for the 35 and the 20, so you don't need that.
0432701 CARBURETOR ASSEMBLY. Not Shown 30 & 35 Models Only
Driveshafts are the same, gearcase internals are also.
hey thanks for the reply good to know the leaf plate is the same, i will look in to the manifold, and carb and wait for more replys see how other have done on here from what i heard the carb and intake and your golden ,bit larger prop to slow down the rpm's? thanks again
boobie
Is it worth the time and cost ?? I'd just buy a bigger motor.
nwcove
there is a mathematical formula that makes the conversion easy. X+Y=35 X being what you sell your motor for. Y being the extra cash you throw in to purchase a 35.
hey,after reading your replys to if its worth it the motor is 600 doll hairs ,30hp carb rebuilt 130 doll hairs and 30hp intake is 10 so for 740 i would have a 91' 92' 30 hp that would push my duck boat and gear better than my 76' 25 which is fine with one guy but i want to rip on a budget of coarse
update, i was able to find the intake for cheap 10 and am now looking for a 30 hp carb primer style from the early 90's ,any pics of the carb of should look for would be great thanks will post pics when i get her home
