I have had my 115 mercury outboard in the shop since early July. I took it in because it would not accelerate properly. Shop diagnosed an issue with water spitting into the exhaust through a leaky gasket. They pulled the exhaust gaskets and replaced. Installed new gasket on the outer housing and replaced the water jacket gasket also. They removed the lower unit and replaced the water pump impeller than lake tested the boat. The lower unit gear case failed during the lake test. Clutch dog came apart and blew a hole in the side of the casing. I found a used lower unit and they again changed the water pump impeller and installed the lower unit than lake tested. Total price $1,134.40.
Is that reasonable?
Thanks, Jim
Is that reasonable?
Thanks, Jim
