BigNiner19
- Joined
- Jul 1, 2006
- 234
Got a late 80's early 90's Johnson 60 HP 3 Cylinder Outboard. Trying to remove the powerhead. The Seloc manual tells me to "remove the three botls on each side of the powerhead, the two in the front, and the two nuts from the studs at the rear of the powerhead".
Does anyone else find these numbers not to add up?
I've removed the two bolts that look to be bolted into motor mounts towards the front of the motor on both sides. I also removed ONE nut from a stud in the rear of the motor at the very bottom of the powerhead (very difficult to get off). Are there any other bolts/nuts???
Anyway, I have everything apart that is supposed to be apart minus the flywheel as I will just take that off once I remove the motor and get the 1" 3/8 size socket for it.
Please help!!! Trying to get this done today so I can start the rebuild.
