chuckndiscs
- Joined
- Apr 18, 2008
- 383
Hullo!
I have a Spirit 65 HP outboard that I cannot get running without squirting gas in the carbs. If I spray gas in the carbs it will start and run until gas is gone. I have ensure (I think) that the pump works. I tested this by pumping the bulb almost hard and the filter is 3/4 full, putting gas in carb, running it for the bit it runs and then feeling that the bulb is hard and the filter is now full. I believe this is a test that pump works. I am planning to disconnect the other side of fuel pump and see how the gas pumps out - strong or other.
I was looking online tonight for a carb rebuild kit for this motor. Figured if not pump its the carb... I pulled my serial and model for help but CANNOT locate the year or where to purchase carb kit (IF ITS STILL AVAILABLE???
) and need some assistance:
Outboard: Spirit 65 HP
Serial: 6501 001367
Model: 650013
Maker: Spirit Marine Division, Arctic Industries
Carb Stamp: MIK (or MKI or MIC - I already forgot!
I did look at browns point marine to no avail. Looks like MOST of their parts are 85 and newer...
Any help on the motor starting (should I do ____ additionally) or the year and somewhere to purchase a carb kit?
Im guessing some but bet Suzuki motors used the same carbs for many models and years and maybe my 65HP Spirit = ____yr Suzuki for the carbs.
Kinda want to fix this outboard up as it is a rare beast AND it comes from Get A Way in Thief River Falls MN! (I am from MN and appreciate local support, even YEARS down the line)...
Thanks for the help!
-ChuckNDiscs
Serial: 6501 001367
Model: 650013
-ChuckNDiscs
