rpuchowicz
- Joined
- Apr 22, 2008
- 11
Went for a shakedown test and everything went smooth until running it at WOT for less than 1 min. It seemed to run fine at WOT but when I throttled downed it stalled and would not start. After 30 min cool-down it started fine. We did not run it any more because I noticed that the temps were a high after the WOT run ? 170-180.
The engine is a 1987 mercruiser 305 with an alpha 1 outdrive. The fuel pump is new and so is the TB4 cap, rotor, and ignition sensor. Plug wires all look good to. Plugs are also new. The carb was also recently rebuilt. Compression is good.
I don?t think that it is a vapor lock problem as the accelerator pump was still squirting fuel after the engine died. Nor was there a choke malfunction. By the time I got around to checking for spark the engine was up and running again.
Because the engine seemed to running a bit hot I tore into the impeller when we got back from the launch. Although the impeller looked well-worn it had not fallen apart.
[URL=http://img183.imageshack.us/my.php?image=impellerxm8.jpg]
[/URL][URL=http://img183.imageshack.us/my.php?image=impellerhousingsg6.jpg]
[/URL]
My first question is whether a worn-out but still intact impeller could cause overheating?
My second question is whether on overheating engine will suddenly cut out? Is there any overheating protection built into the ignition system that would cause and engine shutdown?
As I inspected the lower unit further I noticed something unusual blocking the exhaust passage.
Some rodent built a nest down there out of what seems to be sofa cushion material.
Would this cause an engine to overheat? Would it cause the engine to shut down at high RPM?
Any help would be greatly appreciated? Thanks.
