Hi guys i hope u can help me out...i bought a boat with a 3.0l mercuser its about 1989-1988 with points system..to cut a long story short i got sold a boat that needed a lot of work doing to it...ie wrong gearing in sterndive for a 3.0l which i have got the mechanic to replace with the 1.98.1 gearing and lots of other things that also needed doing...i bought my boat for ?3900 and have already spent over ?2000 haveing work done on it getting it ready for summer...however the mechanic said ok we are ready for a sea trail this saturday and we took it out..its a 19 foot fletcher cuddy sports cruser....it ran great and with 3 guys onboared we where doing over 36mph and i was so happy but then things started to go wrong...it started to misfire bad..maybe on three then two then died on us...he opened up the engine bay and said oh the timing cover is leaking oil must be gasket or both rotted timing cover which will need replaceng...but thats not the misfireing reson...he said he thinks its the coil...so after the boat had cooled it started again fine and we ran it to the quay side where a friend of the mechanic met us with a new coil..so he replace the old coil with this but said we should not go out again today as timing cover is leaking oil and it needs to be replace be for we can go out underload again to make sure it was the coil caurseing the misfire...however and this is where i need some help...i have read on this forum and other forums that my age of boat has a ballast resistance in the coil wiring and will need a coil designed for external resistance...i told this to the mechanic this morning and he said thats not true all mercs are 12v system and said the it does not need a coil designed for external resistance...so can someone please tell me where to find this ballast resistance in the coil wiring so i can show him...or if he is indeed correct please tell me .... i dont know what would happen if he put the wrong coil on but i would like it to have the correct coil for my boat and feel a bit happier at sea without this going wrong in the summer....thx for anyhelp
