Help finding edge trim
bjurcina
Hello folks
I'm in the process of restoring an old day sailor and I've hit a road block. I need to replace the edge trim that wraps around the perimeter of the hull where the upper deck meets the hull. Most of these joints are an overlapping seam and there are a million different types of trim available for these applications. They are usually called the rub rail or gun whale I believe. In my case it is simply 2 flanges that lay on top of one another and are bonded or riveted. The rubber edge trim is just pressed over the sandwiched flange. I've attached a profile picture of the trim. I hope someone out there can point me in the right direction.
Thanks
