my1stboat1
- Joined
- May 31, 2010
- 307
88 force 85 hp engine
Ive had the boat out many times and the nite before i always fully charge the battery... However the volt gauge never goes over 12 volts whether im idling at 1000 rpms or cruising wide open at 4800 rpms.. Today i came home and went to my seloc book.. I put a volt meter on the battery terminals and monitored battery voltage key on engine off.. 11.97 volts... engine running @ idle 12.00 volts and 2000 rpms the peak is 12.07 volts... so i started reading and decided for 4 dollars ill go to radioshack and get a rectifier, Replaced and with no change i got the same results... Like ive said ive had the boat out many times and its always started and ran well But the gauge is never up . SO im concerned.. Any help would be Great...
