Re: Help going nowhere!
Could be cavitation or a spun prop hub. Easy to check the hub ... put an indelible magic marker mark on the hub and another outside of the black rubber. If the marks move are running the motor and experiencing the symptom, you've got a spun hub ... take the prop to a prop shop and they can press in another hub. It's generally under $50.<br /><br />Generally, cavitation does not continue for very long. Typically, if the motor is correctly trimmed for the boat, most cavitation lasts a few seconds, then the prop grabs and you go. If all else is unchanged, and this suddenly started, it's probably a spun hub.
