Re: Help/help/help, is vin gel-coat or plate on a 86 stratos open boat?
Had a place on onota for years, but been on them all! It's just a matter of luck of the draw! Also the mood of the officer, and they have a couple of rookie's, the local big shot retired! I suggest you bring the papers and apply for issued numbers,,,, you call and they come to you and issue numbers, and for any 70's and I believe up to mid 80's its very simple and takes the worry out of it! if they see it ,even on a trailer they will impound! ps SHE called this morning and released the boat and will come out by app. and issue new #'s if I can't find any behind the ss plate that was added to the transom! going to cut square out in the area where it is supposed to be! found a picture of a hull of the same yr and maker so I can see it! By the way, I have had it done a couple times before and there is no cost for it! 70's boats had only a few didgets so they issue new ones no matter what! GOOD LUCK,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,LARRY
