stephenhudack
- Joined
- Jul 2, 2009
- 15
Hey guys i just bought a sea ray with a 115hp merc on it. It has 3 carbs six cylinders. The power head was redone 20 hrs ago compression is great in all three cylinders. I started up boat in my drive way several times and ran through the motionbs several times. The boat would run up to 5500 rpms in gear and in neutral aqnd sound great. SOlast weekend i took it out and found that i couldnt get the boat over 2000 rpms. But still would run tp 5500 in neutral. The boat seems to break up and miss it sounds like after 2000 rpms. I changed all 6 plugs not the problem. I tested all the coils by removing coils from the plugs one at a time listening to the motor, all six cylinders are firing. DOES ANYONE HAVE ANY SUGGESTIONS ON WHAT TO DO NEXT!
