My 1989, 85hp force outboard is not pumping water through the engine. I installed a new impeller after removing the lower unit for shift rod seal repair. Now water is not coming out the exhaust port. With the lower unit off, I even tried to put the water hose into the water tube and force water in. With and without the engine running. Nothing is going through. I'm sure the impeller is in correctly. Why or what is causing this. My Clymer Manuel does not show the route of the water after it leaves the water pump. Is there another mechanical part in there? Also, the shift rod bellow type seal for the shift rod is rotted away. I could not find one. Is there some place to get them? I have been told you have to buy a new shift rod and a new gear case cover with the new seal. I came up with a fix for this. I am trying it out now, will post it when I know it works. I would still like to find the original bellow type seal if possible. Thanks for your help
