Help.. High rev , not a spun hub
natedog337
Hey guys looking for some advice. I have a 26 ft pontoon with 4 stroke Yamaha 2011 with 38hrs on it.. Last year my first season I upgrading to a 4 blade prop with no issues... Prior to this season I removed prop to grease and reinstalled correctly.. It was installed and torqued properly.. Well took it out for its first tide this year and when I get to 3000-4000 Rpm it blows out and revs high and appears to slip.. Thinking I hard a spun hub Ireinstalled
My original prop and same issue except not as noticeable until about 4500-5000 rpm
Any advice on what my issue may be
Thxs everyone
QC
Re: Help.. High rev , not a spun hub
Anything different with OB height? Trim? Bottom condition(s). Weight balance?
natedog337
Well I feel pretty stupid. I've only had the boat 1 year and I found the sweet spot on my trim last year and used the gauge this year to set it exactly in the same place. Well i took a ride with my mechanic after trying to figure it out all day and the gauge or trim sensor is nit reading properly. Motor was trimmed to high. When I put it all the down and eye ball the trim, off she goes with no problems... Well it worked out with minimal aggravation :) thxs again
QC
My first post here, seven years ago, was something stupid. Easy to get sucked into your own BS if you don't always doubt things. I usually do, but that day . . . Live and learn. Your situation sounded like typical high trim blow out for sure. Thanks for the follow-up.
