Help How to change tilt/trim line
Beautiful Lawns
Trying to change out a busted line on the boat. It is the tilt/trim line. How do you remove it from the bottom Section. Engine is a 302 i believe, drive is omc cobra. Everything is a tight fit down their. Please dont tell me the engine has to be pulled???
wire2
Re: Help How to change tilt/trim line
I'm not familiar with the trim lines on a Cobra but I expect it uses hydraulic lines with small hex fittings. The best tool to remove it is a line wrench. It looks like a box end with an opening in the end opposite the handle. Measure the fitting with a vernier and you can get by with 1 wrench, rather than buying a set.
