Help ID a Johnson motor
wauto
I picked up an early 70's Johnson in pieces. There if not a tag on the transom clamp. However I have the numbers off of the core plug. It is 15012 19182. My guess would be a 1970 20hp ?
What colour is this fine motor ?----15012 is listed as a 1953/54 Evinrude.
F_R
No Title
1953-54 Evinrude Fastwin 15hp
F_R
Sounds like you may have a Johnsonrude, if you think it is a Johnson. Made up from spare parts??
wauto
The block is dark green and looks very much like my 72 18hp Evinrude. On my exhaust housing I found some very similar numbers. However these are 18012 19182. So I double checked the plug and it clearly is 15012. Someone at the factory screwed up?
F_R
Dark green would be a Johnson color. But 15012 clearly is an Evinrude number. Hate to say it, but it is beginning to look like a chop shop job. Changing parts and serial numbers to disguise stolen stuff. Yes, that numbered core plug on the block is easy to swap without destroying it.
wauto
Good call F_R, this motor has been painted several times in it's life (duck boat motor). So I sanded down the hood and found under all the camo, Evinrude blue. Then under that White. The exhaust housing goes down to Evinrude blue over the original Johnson green. Not too worried about her sorted past. I live in a state that doesn't register motors, and I bought from an estate sale.
​Next question. Can I measure the bore to determine the motor size?
F_R
Of course you can, if you want to pull the head. A 12hp (Gale) is 2-1/4", a 15 is 2-3/8", a 18-20-25hp is 2-1/2".
