help identify
brogden31
can anyone tell me witch 5.7 this is , 0k026694 my boat is a 96_97 so not sure that's the years they changed I believe
brogden31
and if you know what's my best route to change the block mine cracked
jbuote
Not a pro here, but as for which engine it is, I googled mercruiser serial number lookup, entered your number and got this:
MERCRUISER 1997 5.7LX 457L110KS 5.7L 2BBL 5.7LX 4BBL 350 MAG ALPHA/BRAVO
Hope it helps!
are you changing the whole long-block or just the block? cant simply swap the block without going thru a rebuild
