Help Identifying Holley Carburetor
JDusza
Ensign
Hi. I have what I believe is a 1979 Pleasurecraft Waukesha 302, Clinton Iowa, with a Holley marine 4-barrel carburetor. The MotorCraft tag on the carburetor reads EOJL CA A 1F17. Holley told me they cannot reference MotorCraft numbers. Can anyone tell me the Holley model so I can order the correct rebuild kit?
Thank you,
J
jimmbo
You are sure it's a Holley? Ford did make a carb that at a quick glance was often mistaken for a Holley, though I doubt any of those were USCG certified. As AllDodge said, post a pic.
Boomyal
Look for a list number stamped into the choke horn. If it has one it is probably a Holley number. I am not aware that a Motocraft Holley was ever made in a marine configuration.
JDusza
Ensign
No Title
Thank you. I think I am in good shape moving forward. I flat out pulled the carb and took it home. There are numbers on the choke chimney. And, thank you for the head's up with correctcraftfan.com.
Thank you,
J
Boomyal
......... Holley did make carbs for Ford......
I knew they did, AD, just was not aware that they made them in the marine config. Interesting that the carb in the link you posted is undoubtedly a marine carb by virtue of its "J" float bowl vent tubes. However it is odd that there is no evidence of it having the gold, di-chromate finish which was intended to retard corrosion that could be inherent in a marine environment..
jimmbo
Carb Number
Carb Model Number
CFM
Renew Kit
Trick Kit
Needle & Seat
Primary Main Jet
Secondary Main Jet or plate
Primary Metering Block
Secondary Metering Block
Power Valve
Pump Nozzle Size, Primary
Secondary Nozzle Size or Spring Color
R9392
4160
600
703-33
N/A
6-511
122-66
N/S
N/S
N/S
125-25
0.025
PURPLE
Primary Bowl Gasket
Primary Metering Block Gasket
Secondary Bowl Gasket
Secondary Metering Block Gasket
Secondary Metering Plate Gasket
Primary Fuel Bowl
Secondary Fuel Bowl
Throttle Body & Shaft Assembly
Venturii Diameter Primary
Venturii Diameter Secondary
Throttle Bore Diameter Primary
Throttle Bore Diameter Secondary
N/A
N/A
N/A
N/A
108-13-2
N/S
N/S
N/S
1-1/4
1-5/16
1-9/16
1-9/16
Right from the Holley website,
