Help identifying volvo engine and part
Mengwalton
Good morning,
I have this inboard engine and its running fine however theres a small water leak from what i think is the water pump. I think the engine is a md2 ? They look the same but not sure would love someone to confirm this. Also ive uploaded a pic of the leaking joint if anyone could confirm this is the water pump.
Following the pipe it comes from the sea **** through the gearbox then into this part
Sorry about the quality had to compess to get it on here
​Jonjoe
Mengwalton
Thanks for the reply, after searching around it appears that it is a md7a model however the water pump is almost identical to the one above. I beleive the seal o ring and gasket is only ? 10 ish so thats happy days thanks
J
I believe the original pumps were made for VP by ITT Jabsco.
