Can anyone here help me ID a Suzuki gearset?
I have four pieces, forward, reverse, pinion, and clutch dog that have been put in the wrong box (I think). There are no numbers at all on any of the parts. They are in a box for a 2001 up DF70 HP four stroke, and labelled 57300-99823.
But, the gears are much larger than the same gears as used in the 1999-2000 DF70.
They are at least thirty percent bigger overall, if that makes any sense.
Did they significantly increase the size of the gearset when going from 2000 to the newer 2001 design? Or do I have a V6 gearset in the wrong box?
I can give dimensions, tooth counts, etc. I would really like to ID this as it is a high dollar part.
Thanks in advance.
Thanks in advance.
