Help I'm loosing my Mind
Devin3200
Quick question ,,,, actually two questions. Maybe someone will know the answers.
One, I have an 89 bayliner with a 125hp l drive engine. I'm completed the exhaust manifold casket replacement.. PITB..... to say the least. I had to pull the engine for better access and retread a few ports. ( broken bolts and what not). I trying to get all of the electricals back in place, but for the life of me i can understand why i missed taking a picture of one last cable. I can't figure if its just ground cable and to where it will ground to. (engine or the block near the solenoid)
i'm attaching a pic if anyone can tell me that would be great. Also as i have it installed near the solenoid, i tried turning the key and i broke the positive cable off the battery. so something is not right. Help!!! Note its the cable with the white stripped shield cover . Two black wires are in there and have a connector to be screwed in somewhere( ground).
The Black should be the ground for the trim pump
Is that two red wires or just one?
If its one, whay is it connected to the stud on the block?
