nearpar
- Joined
- Sep 4, 2010
- 143
I have a 17ft Sea Nymph with a Mercury outboard I purchased the boat and it needed to be rewired. I made a new dash out of aluminum and gutted 90% of the wiring. Everything is going well I soldered and shirked wrapped all connections and installed a new Electrical panel in the boat. I also installed a Nice voltmeter in the dash, but I am not sure how I should wire this ? Should I run it direct to the hot side of the Distribution panel with a fuse, and switch it on when I need it ? This boat is equipped with and outboard motor the ignition switch is located in the throttle assembly. I think it would be difficult to try to switch it on and off with the key...
