ratlsnaktj
- Joined
- Mar 26, 2008
- 31
I'm somewhat a beginner at doing my own engine work on my 1983 V150 and need some help with figuring out what the results from the testing I just did means.
I tested the engine per Seloc manual and got the following results:
Ohms Between:
Blue/Wht & Red/Wht leads - 2.6 Red & Blue - 2.7
Red/Wht lead & powerhead ground - 68
All of these come in below what the manual says.
I researched a little more on here and found a post by Laddies that had specs and procedure from CDI http://forums.iboats.com/showthread.php?t=224065&highlight=switchbox+testing
Those results are as follows:
Blue - 0
Blue/Wht - 0
Red - 68
Red/Wht - 68
I know the DVA testing is much better but like I said I'm new to this and don't have the DVA tester yet. Based on the results I got what should I do next? Any help would be much appreciated.
Ohms Between:
Blue - 0
Blue/Wht - 0
Red - 68
Red/Wht - 68
