Help please! My johnson 25 will not pick up water. I figure the impeller <sp?> is shot, but I have no idea how to get to it. Any suggestions?<br /><br />Thanks,<br /><br />Chris
Hello.<br />There are plenty of ideas about how to get to it.<br />It would help if you write us the year and model # of engine.<br />Buying a manual before you start the job will save you a headache or two.<br />But before anything else, maybe you can check if the intake is fouled up,because your problem could be that simple.<br />Good luck
The intake is good. I also tried to blow it out with an airhose, no joy there either. Its a 1994 25hp Johnson Outboard, model j25rerc.<br /><br />Thanks,<br /><br />Chris
