Hi all,
I just obtained a 14ft Mirrocraft aluminum boat with a 20hp Johnson outboard. It looks like an older Seahorse model. Here are the model & serial numbers:
Model: FDL 22M
Serial: J2924796
My guess is that is was made in Fond du Lac Wisconsin, June of 1979. Not sure about that, so if anyone can tell by the serial number I would appreciate the help in putting an age to this motor.
It has sat for about 2 years, so I am planning to dump the gas. Plugs look good. A couple of questions:
1. Anything else I should think about doing before firing it up?
2. What would the gas / oil mix be, 50:1?
If it starts, I am thinking I will probably sell it and replace it with a 9.9 HP or a 15HP. Any thoughts?
Thanks in advance for the help!
Doug
Model: FDL 22M
Serial: J2924796
Doug
