Re: Help! Johnson85HP 1980 Will only start after turning fuel valve to manual st
Hi skylar, if you are referring to the red handle on the primer solenoid, then your solenoid may be shot or there is no voltage getting to it. If you have a volt meter, clip the red lead to the purple/white lead going to the solenoid and the black lead to ground. Turn the key on and push to choke. If you have 12volts to the solenoid, and it does not "click", then the solenoid is bad and needs replaced. If the solenoid does "click", take the head off the solenoid, four small screws, and make sure the plunger is free and operating. Watch that the spring don't fly out when you remove the head cap. Hope we have helped.
