Hey, just bought a 1990 Sunbird Stinger with a 2.3 OMC Cobra. It has a strong fuel smell and it the fuel and i'm trying to get stuff cleaned up before I take a good look at everything. I emptied all the fuel from the tank and took the boat to the superwash and sprayed everything real good. I was spraying the hose straight into the drain in the floor storage compartment in the front of the boat and seen that a gas-water mix was coming out of the bilge drain. I then pulled up the the inspection holes above the fuel tank and sprayed in there real well. I thought this would drain out the back as well but instead it filled up to the inspection holes! Should this happen or is something plugged and stopping it from draining? I syphoned the water out and it is now drained but I want to know if this is normal. If it is and I do have a leak in the fuel tank how is that gas getting into the bilge since it seams like the tank is contained seperately from the rest of the bilge? Thanks!
