HELP lower unit remove
andrewcoon
I have a 66 johnson golden meteor 100hp I have all the bolts off and it wont come off I disconnected the shift wires but do I have to pull them down? If so how do I do that? Thanks
castires
Are you sure you got all the bolts? There's some from the inside of the housing as well as from underneath it.
sutor623
Re: HELP lower unit remove
Is there a bolt holding the shift linkage together? They are hard to see, and sometimes hard to get to. The shift rod has to come apart, and then the L/U will come right down. Thats how all of my Johnsons have been.
F_R
It's electric shift. No shift rod.
1. Disconnect the shift wires by the powerhead exhaust cover.
2. Remove the rear lower motor cover and rear exhaust housing cover as a unit. Remove the clamp holding the shift wires below the thermostat.
3. Remove the six nuts holding the gearcase to the extension housing, and the two bolts holding the extension housing to the exhaust housing.
4. The gearcase and extension housing should now come down as a unit.
To be honest, I don't remember if there is anything else to deal with concerning the shift wires. Take a good look and use common sense. I can't remember everything.
