Re: help me decide
Late 80's/Early 90's "new-design" 3's and 4's have bottom-guided rods, i.e. the rod big end thrusts upon the sides of the crankshafts. In this motor, it caused problems with excessive wear on the crank and failure of the rod bearings. My buddy bought a 90 which had blown up because of this. Replaced the crank, rod, piston, welded up the case, and it ran like a champ!<br /><br />Merc changed the design of the motors in the mid-90's to a top-guided rod, whereas the thrust of the rod is taken up at the wrist-pin end, and the big end of the rod just 'floats' on the crankshaft. Apparently more durable and produces less friction for more power, too.<br /><br />That notwithstanding, probably takes many many hours for this design flaw to arise, if ever. <br /><br />You've definitely got to hear both motors run and if the 75 sounds great, it'll probably be a better motor all around than the 80. Just be sure to use non-alcohol fuel and a premium, synthetic oil. Wally's sells Penzoil full synthetic for a great price and have seen good reviews on the oil.<br /><br />HTH.......ed
