The Revenge
- Joined
- Jun 1, 2010
- 60
Thanks in advance.
I'm looking for some feedback from you guys on how you would lay out this dashboard.
I'm ready to start cutting.
I created a gauge/layout simulator. The white paper is the same size as the dash and the gauges are the correct size. In the center of the paper you will see the helm and where the steering wheel will sit.
The first example I have here is a simple layout leaning on the chart plotter to provide most of the data. Volts, speed, radio operation, etc.. The fuel gauge will be a mechanical gauge on the tank.
The second example gives you more to look at and what I like as far as bare necessities.
I'm open to ideas. What would you add, leave out, change, etc?
Thanks again
Thanks again
