I bought this boat last year (89 cheetah, 3.0 merc, alpha 1) and when test driving it i noticed what sounded like a bad gimbal and / or u-joint. I separated the drive today and water came pouring out of the gimbal housing. The u-joint bellow appears to be fine, but i did fine some metal ring in there that i wasn't sure should be there. I pulled part of it out so you can see it in the picture, not sure if it is there for supporting the bellow or not.
any way the boat has only been in the water for about an hour this year and that was over a week ago, i've never noticed water leaking from the drive when it is parked, so that makes me wonder if maybe it is coming from a coolant passage
what all should i check and what is most likely the problem?
