Help Me Identify My Carb...
cshirley
I thought it was a Rochester 2GC. It has the electric choke and looks like the pictures of the 2GC. The engine is a 1978 Mercruiser 470 - 224ci. I went with the application for that engine but the carb kit gaskets don't fit. All of the metal/plastic hardware in the kit looks fine and the float is identical to what is in it but the gasket around the 2 barrel section of the carb is too small.
The parts I ordered:
Mallory Carb Kit 9-37616
Mallory Float, carb 9-36903
The numbers stamped on the side of my carb (I haven't been able to locate anything referencing these numbers)
06079A-1
4Y03
Thanks for any help! The carb seemed to be flooding out so I figured I'd rebuild it but, it actually looked great inside (recently rebuilt), although I think the float adjustments were wrong.
Don S
Re: Help Me Identify My Carb...
How many idle mixture screws are on your carb?
The Rochester has 2 mixture screws, the Mercarb has only 1
While they look similar, the gaskets are not the same.
cshirley
Me and my dad noticed that. Where it looks like the two idle air screws would be , they are blocked with brass, in between them is one long adjustment screw.
Don S
You have the Mercarb, not the Rochester. Wrong rebuild kit.
cshirley
How do I find out what model year so I can find the right rebuild kit. I've tried tracking down the stamped numbers with no luck.
Don S
What's the Mercruiser SN of your engine? Or just look it up for a 78 470, and it should show the Mercarb.
cshirley
Don't have the serial number currently but looking up the year, 1978:
470 224/ L4 1976 - 1982 4208730-6218036 R2/2GC (1)
470 224/ L4 1983 - 1984 6218037-6916778 M2/MerCarb
It shows that the rochester was used and not the Mercarb. Thats why I chose the rochester rebuild kit. This must be a different carb than what came on it.
Don S
Obviously, the original carb was replaced. Which isn't hard to understand on a 30 year old boat motor.
Can't help you with your carb numbers, but you might look at the 83 to 84 Mercarb kit.
cshirley
Ok thanks, I'm gonna try and see if I can find a serial number. Is there a standard location for it on the carb?
Thanks
JustJason
should have been on a metal tag screwed on the bowl cover someplace... but ya probably don't have it
just post a picture
