Ive been working on a project boat for the last 5 months.... it finally hit the water today
The boat is a 17' Anacapri with a 2000 130hp yamaha. The first prop i had to try was a 21p standard yamaha ss prop (the black painted one with the straight trailing edge blades). As I suspected, it was over-propped, but worse than i thought. It turned 4800 rpms at 43mph one direction, and 4900 at 44mph GPS in the other direction, and this was trimmed way out. The motor is 2:1 gear ratio. This was with a full fuel tank, about 50lbs worth of coolers/gear, and just myself in the boat.
In addition to being overpropped, i noticed the boats attitude doesnt respond to trim very much, not as much as id like. The prop was fairly easy to blow out while turning sharply as well. The vent plate is right at about even with the keel.
Any suggestions for props? Definitely going with an SS prop. Im thinking a 17 or maaaybe 19 of some sort with some cup to it?
