help me please !!!!
waterdawg69
is here a way to take this off (marked on picture)
Re: help me please !!!!
That would be the bell housing, and to remove it you remove the two hinge pins it swivels on. One is barely visible in your picture. Then you will need to remove the bellows and shift cable to get it the rest of the way off.
waterdawg69
thanks i got that took care of now what kinda of glue do i need to use to put new bellows on with?
Rob454
No glue. usually clamp on the boat end and then the other side has a lip that gets fitted over the housing you jsut took off
Rob
Bt Doctur
The bellows and shift boot are glued on using bellows adhesive, weather-strip adhesive, contact cement,etc.the only one not glued is the exaust bellow.
waterdawg69
thanks for the help guy mabe everything will go smooth now
