I have a 19ft 2000 Starcraft Islander - 3.0L 4cyl Alph 1 Gen II 2:1 ratio - 2600lbs Using Smart Tabs (They work great)
Prop I have now - 15x17 3 blade aluminum.
The engine is in excellent running order. Tach and GPS Confirmed.
At 4800 ft above sea level. Wide open throttle - trimmed appropriately 4200 rpm = 29 mph
At 0 ft sea level. Wide open throttle - trimmed appropriately 4500 rpm = 32 mph
I am considering a 4 blade replacement but 3 blades may be more appropriate.?
The boat is used for fishing. I have never towed a skier or boarder, tubber.
I would like to get greater top end speed as well as good performance if possible. I don't believe I would care for separate props for the difference in elevation but would consider it if I had too..
I used the general formula for determining mph and was spot on I believe.
RPM divided by gear ratio X pitch divided by 1056 - 12% slip = speed (29.7 mph) pretty much bang on!
I am trying to get the prop right on the first try because I have to order the prop and shipping and duty apply.
Thanks Steve
Thanks Steve
