dohcdelsol93
- Joined
- Jul 13, 2010
- 97
I have a 26 ft flybridge I'm restoring. Haven't ever heard her run. Compression test yielded low numbers on #1 cylinder. Engine is coming out while i rewire and reseal everyting so whether its just a freshinging with new rings and a hone plus bearings she's getting torn apart.
I aleady have a set of machined vortec heads to slap on
Already have an hei marine dizzy to slap on.
What cam would you suggest? Standard oil pump or high volume? I have raw water cooling. Unless i find a boat being scrapped and get a closed system shes staying that way. Whats the best sorce for new exhaust manifolds and risers? Mine are center mount i believe. Reliability is most important. Fresh water use with maybe one to three beach trips a summer.
I plan on a regular vortec automovie carb intake ,aluminum, with zincs installed. I can buy 4 for the price of one marine.
Was Planning on rebuilding stock carb but will it put out enough cfm? I have not looked to see if carb has electric choke or if it's run from the heat off of the intake. If it is can this be adapted to the edelbrock perfomer rpm intake manifold?
Going for mpgs here not mph but woukd like to pull my son and nephews on a tube, maybe knee board.
Pre alpha with an alpha 1 slapped outside.
Also what all would you replace while it's out and outdrive removed? Im thinking minimum gaskets sealing outdrive housing to the hull. Links to said parts would also be nice. Im a sailor so i dont know specific terms for outdrive parts.
Thanks guys. Advice is welcomed.
