I pulled the powerhead off my 1989(A) Force 15 HP. I can see where the water supply tube inputs water to the powerhead, but I don't understand where the hot water is ejected from the powerhead. This Force doesn't have the traditional "pee hole", it just sort of spits water out of the exhaust ports from the back of the motor, quite a ways down from the powerhead. I removed the exhaust cover (right word??) from the powerhead to have a look, but didn't see any port that hot water would be ejected from in the powerhead. Am I missing something here???<br /><br /> Also, when I had the exhaust cover off, I noticed one of the pistons was scored (could see them through the exhaust port). Checked the rings to see if they were frozen and they were not. I could rotate them on both pistons. With the engine warm, both cylinders read about 112-115 PSI, with the engine cold one of the cylinders is down to about 90 PSI. Is this a major problem??? The manual states to check compression with the engine warm, which is when the compression is OK. I suspect the motor was overheated before I bought it (had a new W/P impeller). Any advice, thoughts, jokes, or sarcasm greatly appreciated!!!!!
