Okay, <br /><br />This is an update to a post I had made a few weeks ago when I noticed my motor spitting up a rooster tail at half all the way up through full throttle. <br /><br />Today I put it at 2/3 throttle and walked back to have a look at the cause... <br /><br />I noticed it was coming up from right behind the lower unit above the anti cavitation plate. It almost looks like my hydrofoil fin is the cause of the problem... <br /><br />Now I want to know if the rooster tail is part of the design or if it isn't supposed to be doing it??? <br /><br />Here are some pictures. As you can see, the water gets compressed between the front of the lower unit and the inside of the hydrofoil and makes its way back and hits the hydrofoil crossmember and as a result is deflected up towards the motor. It almost looks like the rooster tail is planned and is part of the design, as the crossmember is beveled at an angle to shoot the water up??? Anyway here are the pictures. What do you all suggest I do? Besides a little drag/friction, it doesn't really affect my top speed, and the hydrofoil does get me on plane faster... <br /><br />
<br /><br />
