Re: Help, My 9.5 Evenrude Motor is Choking & Smoking!
1) You need a new gasket that fits between the power head and the lower unit. Buy a manual for your engine. The job is not as hard as it is time consuming...about 3 hours for a novice w/all parts on hand. Keep up with all the parts you remove to insure a hassle free re-assembly.<br /><br />2) If you use the proper plugs, they come with a metal compression gasket that should properly space the plugs in the cylinder head. If you are using the correct plugs (Champion J4C or Autolite 353) with the compression gasket that comes with them, and the pistons are still hitting them, then you have serious internal problems (rod and/or main bearings) that must be addressed ASAP.
