rs6529
- Joined
- Sep 9, 2012
- 6
So here's the scoop. I have a 200 hp 2 stroke. Symptoms are this. Starts and runs, I have to give a little more throttle to keep it idling. When I shift it in gear, it will die. Basically I have to throttle up then shift it into gear hard to keep it running. I have no top speed. The first issue was that it was surging while 3/4 throttle.
My mechanic tested and determined that I only had spark on 2 cylinders. He later tested and I only had spark on 1 cylinder. He was 90% sure it was the trigger. $125 dollars later and have the same issue. He left for vacation, and suspects maybe a coil.
Any thoughts or experiences before I start buying all new coils and a stator etc.
Thanks for any help.
