Help: Mystery valve drips water when engine is running
kburks1230
Can anyone help me identify the purpose of this nipple sticking out of my engine? It drips water when the engine is at idle and I assume also when under power. What should I do about this? Engine is a 1997 175hp Johnson Fast Strike. It's on a 79 Aquasport 200 CCP that I just bought and am trying to get ready for launch.
See picture here:
http://www.flickr.com/photos/58607046@N02/7823370316
Willyclay
Re: Help: Mystery valve drips water when engine is running
I believe that is a cylinder head pressure tap for a water pressure gauge and the hose connecting the gauge has become disconnected. If it only "drips", it must be blocked with sand and/or corrosion OR the water pump is not pumping very well. Fortunately, you do not have water spraying inside your motor cover. There is an OEM "plug", p/n 0332135, that is made to block that off if no gauge is used. Should also be a tap or plug on the other cylinder head. Good luck!
kburks1230
Great news. I'll plug it when I have a chance. Thanks
