Re: help!!!! need parts!!! old evinrude, where can i get them?
Does your engine need a rebuild or a tune-up? If compression is good, chances are you can do a few routine maintenance things and have a solid runner. Many parts, such as ignition components, waterpump impellers, tank rebuild kits (for pressure tanks), carb kits, some gaskets, etc. are readily available. NAPA carries a lot of those parts, as does your local Johnrude dealer. Biggest issue is getting the lug behind the counter to dust off the old parts books/microfiche to look up the part numbers! Many of them don't realize that the 1957 18hp shares a lot with the later 18s, 20s and 25s up into the 1970s.<br /><br />Let us know what you need and we'll get you pointed in the right direction...<br /><br />- Scott
