help need resources to rebuild evinrude150
spot93
hi,<br /> I have nevr rebuilt an outboard motor ,although i've rebuilt many car motors,i'd like to give it a try.I have the tools & facilities i just dont have the knowledge on outboard motors.I need some <br />suggestions about which rebuild manual to choose<br />& where to find them , where to get parts , & any tips that you might have.I dont know the exact size of my motor , it is a 150 evinrude model#<br />E150stlcos.I have low compression in 2 cyl. therefor im attempting this rebuild.Any response<br />would be GREATLY appreciated!<br /> thankyou<br /> bwr
infish
Re: help need resources to rebuild evinrude150
Hi How are ya? Don't know if this will help or not but I was going to rebuild my 1986 150 Johnson<br />GT. after all the research I did come to find out I was much better off to send it out to get it done. I used Blackbird Industries.Thay do a great job I talked with mike I know he will lead you down the right path. Also you may want to read about the special machines that they use,It will give you 20% more power that reg. rebuilt. I just got mine :) back a few weeks ago, and words can't tell you how great a job they did.I had to turn around to see if that was the same motor on the back of my boat. Give them A try the web address is 1outboard.com let me know how you make out <br />Tony
almost retired again
Hi Spot 93,<br />The rebuild is not beyond what most mechanically inclined persons can do. However I wouldn't attemt it without a good factory repair manual. I think that you can purchase one or have it ordered through most Johnson/Evinrude dealers.<br />Have fun
kenthrussell
Hi there well last year I completely rebuilt my 200 hp merc ..........rings bearings seals pistons, and had bought a manual from clymer and found it was very good. I rebuilt it on my dining room table as this was the cleanest place that i felt ( wife didn't like it and no one over for dinner for a couple of weeks ha ha!) just take your time and check everything twice, I also used loctite on all fasteners and paid attention to all tolerances.Biggest thing i found and hard was someone trying to talk to you well you were busy concentrating on what you were doing. No distractions ----period! Now I have about 25 hrs on the engine and running great...........after the summer checked compression and all six cylinders were 124-125 lbs .............and the big plus was self satisfaction , and really seeing what makes these engines tick sort of speak. Well good luck and happy boating!!!
chumbucket
Kent can we all come for supper now with dining room table clear now ????????
