HELP NEEDED Force 125 not starting
fishinfiend
When i turn the key on the ignition all i am hearing is a clicking sound what does this mean ? Any ideas folks? Where do i start?
letsgofish
Re: HELP NEEDED Force 125 not starting
aloha, while im not very familiar with outboard motors, in cars, usually a clicking sound when trying to start is a bad starter. might want to check resistance to see.
catfishcarl99
dead battery, bad terminal connection. stuck starter shaft. all places to start. or the solenoid. test battery in your truck or car or with a meter. if its not holding charge that could be it. mine last week did the same. the neg terminal was loose. a tap and snug with wrench it fired right up.
jerryjerry05
Picture 346.jpgTach and stuff 021.jpgTach and stuff 020.jpgPicture 004.jpgPicture 001.jpg
First pic is a jig I made to hold the brushes to reinstall.
The rest are pics of a nasty (good) starter.
Check all connections.
Then check the solenoid:test light on both terminals as someone turns the key.
Light on both?Then the starter is bad.
Easy to clean and repair.
fishinfiend
Thanks all I reply back with the outcome shortly
