Hi Folks,
Just finished putting the rebuilt heads back on and ready to install the distributor. Distributor shaft was removed and cylinder was cranked/turned for compression test without distributor in. My knowledge is limited to find the #1 TDC so need help on how to confirm my distributor is firing the #1 cylinder? I watched a vidoe on youtube and it says to line up the rotor pointing to #1 cylinder. Is it correct and how many degree offset for this 92 5.8L engine? Thanks.
Frank
Frank
