Help needed propellor interchange with 1988 88 special
appleo
Any place I can find a table showing omc engines that I can swap props with?
I need a prop and want to get a parts motor with compatible
Thank
jestor68
Re: Help needed propellor interchange with 1988 88 special
If you're talking about a Johnson or Evinrude "88" V-4 motor; it will use the same props as any other V-4 motor with the same size gear case.
jestor68
If you're talking about a Johnson or Evinrude "88" V-4 motor; it will use the same props as any other 1981-1996 V-4 motor with the same size (V-4) gear case.
